TwinTurbo.NET: Nissan 300ZX forum - Replace those injectors. You've found a problem so tackle
flashstar
on July 23, 2015 at 12:23 PM
1-4 were 14.5, 15.5, 24, 15 ohms. Haven't tested 5-6 but..
posted by Mikester(Seattle)
on July 23, 2015 at 12:21 AM
that before worrying about what might also be amiss. You could run a leakage test as well to check engine health.
Lacking power in my 91 NA. What's next to check?
Mikester(Seattle)
00:26:10 07/22/15
Timing 10 ? should be 15 +/- 2. What do the injectors ohm?>>
ZUL8TR
03:54:45 07/22/15
My mistake; 15 degrees. I haven't tested injectors yet..
Mikester(Seattle)
13:13:03 07/22/15
drill a small hole in the center of the broken stud >>>
ZUL8TR
14:17:11 07/22/15
Mikester(Seattle)
00:21:52 07/23/15
Hot or cold the range is 10 to 14 ohms. You are above that
ZUL8TR
04:40:31 07/23/15
Replace those injectors. You've found a problem so tackle -
flashstar
12:23:01 07/23/15
Thanks guys! I'm on it. :) (n/m)
Mikester(Seattle)
15:35:30 07/23/15
